2010 Arctic Fox 25P slide
kingfisherpa888
When i extend my slide all the way out it is bending the angle iron mechanical stop that the adjusting set screw rests against.Could there be a problem with the pressure sensing motor?
thanks Lary Luchinski
2 REPLIES 2
GeoBoy
That is a Power Gear slide.
brulaz
Is that an Alko Axis or RBW slide mechanism? There's a long rack with driven by a pinion gear, with an intermediate drive shaft pinned to geared down motor assembly.
IIRC mine is model GSO-48829-1.
The motor of that thing is powerful enough to snap off the welded-on angle iron stop. It also tore up the intermediate drive shaft while I ran through several shear bolts.
After replacing the drive shaft and using Grade 8 shear bolts from Alko (think the originals were SS), I've been much more careful about hitting the stops. Now I just make sure the seals are reasonably secure around the edges.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
