Jan-26-2015 05:26 AM
Jan-26-2015 06:01 AM
Jan-26-2015 05:52 AM
kaydeejay wrote:
The door post will have a "Tire loading information label" It's black and yellow.
On it is a number called "occupant and cargo capacity" (or similar).
That is EVERYTHING the truck is rated to carry. You mention between 1280# and 1550#. That label will have the number for THAT truck.
Subtract you and hubby, hitch weight plus anything else in the truck from that number.
What is left is your LOADED pin weight available.
(Hint, for a 7800# F150 it won't be much)
Using your max number of 1550# I suggest you will have under 1000# for the fiver pin. (Closer to 700# if it is the 1280# number!)
Not many fivers have a GVWR of 5000#!
My opinion only, but that truck is not suitable for an average fiver. It is limited to very small and light units only. You would be a little better off, but still limited, if it was the HD/Max tow version with 8200#GVWR.
I suggest you forget "1/2 tons" if you want to pull a typical fiver. Some modern 3/4 tons are very capable but a 1-ton SRW would give you lots of choice of fiver to pull.
Alternatively, choose the fiver, THEN buy a truck to fit.
Jan-26-2015 05:44 AM
Jan-26-2015 05:43 AM
Jan-26-2015 05:41 AM
