2017 Ford F350 4x2
buc1980
Anybody who want to order a new truck be aware that you can't order one with 5th wheel package.You got to go thru dealer to install in the house.That is a big problem because the dealer need to replace the bed to install the package under and on top of that they need to drill big hole in the brand new bed.I don't understand why Ford do it on 4x4 and not on 4x2.I try to let everybody know about the problem may be Ford will strait the problem.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
5 REPLIES 5
lenr
I got the Ford package for our 2012 and it resulted in a big Reese expense for a slider hitch. If doing it again, I'd skip the Ford package and do after-market B&W.
buc1980
No I try to talk with Ford no success yet.
blofgren
Did they state the reason why?
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Learjet
I saw that also. Not happy
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Powerdude
That's just weird.
2016 F250 CCSB 4x4 6.2L
2001 Lance 820
