71 Jayco crank question- rookie mistake
tailgunn
I was trying to put up my camper for the first time but I must have been cranking it the wrong way and the sleeve that the crank slots into unscrewed from a shaft. I can't get it to screw back on. There is a cover that screws onto the outside of the camper that covers the slot and keeps the sleeve from popping out. Do I need to remove that cover in order to access the sleeve? It seems the only way that I can possibly screw the sleeve back on.
0 REPLIES 0
