A/C Auto Lo?
thirtydaZe
Bought our 2019 Jayco 324BHTS a few weeks ago, aside from getting it loaded up and keeping it plugged it, we haven’t really done much to it or been in it.
Today it finally got hot, thermostat was reading 99 inside. I turned on the air, and since we were not going to use it until friday i turned it to AC auto lo.
Didn’t really do much. We could hear the ac unit running on the roof but the fan wasn’t blowing any cool air through the ducts.
I hit ac hi auto and it runs perfectly normal, as in any camper we've ever had. The thermostat clicks it off at the correct temp and it cools well.
Quite frankly i’ve never seen the ac auto low feature so I dont know much about it.
Seems to me we’ve had either hi, or auto, where hi runs nonstop.
Does it sound to be operating correctly? Ac unit running, but no fan blowing cool air?
We do have a 2 unit TT, and am not sure that has anything to do with it.
Just looking for clarification. Our past 2 rvs have been 5th wheels, so we are in Downgrade mode.
2019 Jayco Eagle HT 324BHTS
2024 Ram 2500 68RFE
21 REPLIES 21
thirtydaZe
I appreciate all the help. it's just going to go on the warranty list.
2024 Ram 2500 68RFE
Sam_Spade
Brand new unit.
It has a warranty.
USE IT.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
time2roll
thirtydaZe wrote:
Is this suspected wire in the thermostat itself, or located someplace else?
If you are inclined then open the thermostat and check for a loose or disconnected wire. And check same up in the A/C unit.
newman_fulltime
wnjj wrote:
thirtydaZe wrote:
Yes, Low does not work in any mode, just got done messing around with it. The front AC is flawless.
It connects to the back of the thermostat on one end and the A/C unit on the other.
Some thermostats connect the wires with friction locks and it’s possible they got the insulated part of the wire in there too far. It couldn’t hurt to pull the thermostat and check. Look for a GL or gray labeled pin.
If you don't have a through ceiling ac then you have to go on the roof take the ad apart the control box is in the area where the filter would be
wnjj
thirtydaZe
2024 Ram 2500 68RFE
newman_fulltime
My bet its a Coleman and the low speed fan wire fell off the control box
thirtydaZe
wnjj wrote:
thirtydaZe wrote:
So what i have is an AirXcel thermostat.
The cool function has hi, low, auto, auto hi, auto low.
The lo function does not do anything besides run the compressor.
From what wveryone has been saying, im assuming its a warranty issue.
So does the fan run by itself in 'Fan lo' mode?
The RV wiring should have 3 wires used for cooling:
1. Cool - runs the compressor
2. Fan low - runs the fan low speed
3. Fan high - runs the fan high speed
In 'Fan low' mode the thermostat turns on #2.
In 'Fan high' mode it turns on #3.
In 'Cool low' mode it turns on #2 always and #1 when cooling is needed.
In 'Cool high' mode it turns on #3 always and #1 when cooling is needed.
In 'Cool low auto' mode it turns on #2 and #1 when cooling is needed.
In 'Cool high auto' mode it turns on #3 and #1 when cooling is needed.
If wire #2 is not connected, there will be no fan in any of the 'low' modes.
great question, thanks for bringing it to my attention. will check it out.
2024 Ram 2500 68RFE
wnjj
thirtydaZe
2024 Ram 2500 68RFE
trail-explorer
prichardson wrote:
The fan should always run with the compressor. On most RV units there is not that much difference in airflow between hi and low speed fan.
On Auto, the fan will only run when the compressor kicks on.
Bob
Sam_Spade
thirtydaZe wrote:
I was unaware if the design was to just have a trickle of cool air, but i'm certain it's an issue.
It's never "just a trickle".
If you can't feel it and you are SURE that the compressor is running, then it isn't right.
Note: Leaving the fan on "manual" regardless of the speed tends to dehumidify less than "auto" and thus usually is not desirable.
P.S. Getting upset over "trash" answers that come back hurts nobody but you. ALL public forums have them. Chill.
thirtydaZe
I'll double check my thermostat brand when i get home.
I am pretty sure when i kicked it on it went to
Fan Hi, Lo
AC Hi Lo Auto
Heat - and im not sure what options it had.
Definitely though on AC when set at Lo, Auto was also displayed, the compressor was running, and there was no fan.
2024 Ram 2500 68RFE
1968mooney
thirtydaZe wrote:
DownTheAvenue wrote:
So, a 5th wheel is superior to a travel trailer? I wonder whey a travel trailer is a down grade from a 5th wheel. Could you please explain.
Are you a troll or a fool? I came here for answers, you may notice the intelligent people giving advise on the situation.
Just ignore him. He doesnot know how to post without a snob remark.
