A/C unit upgrades
tony5416
Hi, Im sure this has been asked before but im new so if you can point me to the right forum. thanks Tony.
2006 thor 260bh 29 ft. A/c upgrade questions
11 REPLIES 11
colliehauler
Parking in the shade (if available) will make the largest difference. Running a fan circulating the air will help as well. Keeping the blinds shut also helps a bunch on single pane windows. RV'S just don't have much insulation.
1320Fastback
tony5416 wrote:
It looks like the atwood is about 20 lbs heavier than some of the others. Will that be a problem with my 13 year old tt? All the units I see have heat pumps. isn't that just something else to break if i wont be going in the cold?
Thanks
Tony
Our Aircommand 13.5 Non Ducted is also a Non Heat Pump model. It weights 84 pounds and our roof holds it without issue. I would think the condition of your roof matters more than the age. When your up there working on it your adding your weight to the roof structure too so don't think a extra 14-20 pounds will matter much.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
trail-explorer
What's your question?
Bob
tony5416
Thanks
Tony
1320Fastback
13.5 and 15k should both use a standard 14"x14" roof opening.
If you want stay with a 13.5 get a Atwood, it'll out cool any other 13.5 on the market while being much quieter and more electrically efficient.
Route_66_Travel
I have a 15k and it just wasnโ€™t getting the job done. Last summer it would run all day when it was 100 outside and the best I could get was 80 inside. After I watched the following video and sealed leaks between the ducts and the roof, sealed the air separator leaks inside the AC I can now see 74 degrees in 105 degree temps. Plus it cools so much faster than before.
Watch and learn:
AC Improvements
Hannibal
Does it make a noticeable improvement? Our 13,500 is marginal in the summer heat with no shade. I too would upgrade to a 15k if it made enough of a difference.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
the_bear_II
We went from a 13,500 to a 15,000BTU and it fit the existing bolt holes and opening.
tony5416
Will the unit bolt up using existing mounting bracket and electrical connection.
colliehauler
If you have a 13,500 you can upgrade to a 15,000.
Flute_Man
What is your question?
Jerry
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
