? About a particular TT
rickhise
Do they manufacture a TT with opposing slides
with a dry weight of less that 5500 lbs.
Didn’t know if that’s unrealistic or not thanks
7 REPLIES 7
ktmrfs
rather than looking at brochure "dry weight" look at the yellow sticker in the trailer. that will list (at least on trailers built after about 2010) the actual weight as it left the mfg. It does not include the weight of batteries or the weight of propane.
And for empty tongue weight it usually is WAY off what actual tongue weight will be. First it excludes the battery(s) and propane, which immediately add almost directly to tongue weight. Or weight of anything you add.
In my case empty tongue weight from the factory was around 800lbs, but actual tongue weight loaded with water etc. is 1400. Quite a difference!
2011 Keystone Outback 295RE
kellem
Oh and if your wallet is over weight, check out Lance.
kellem
As mentioned, dry weight is fictional and should be ignored.
A wise method to use....make sure your TV can safely tow the GVWR of trailer.
And yes,I learned the hard way years ago
Huntindog
TTs are a lot like people.
They tend to gain weight from the day they are born.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
trailer_newbe
Some manufacturers list the delivered weigh as configured. Jayco is one.
2018 Jayco White Hawk 28RL
GrandpaKip
You need to quit looking at dry weight. Instead, look at the Gross Weight.
That is the dry weight plus the cargo carrying capacity.
The Keystone above is about 7500 pounds max loaded.
That’s over 1100 pounds tongue weight at 15%
That doesn’t give you much left from your 1604 pounds payload of the truck.
Usually, the dry weight listed is way off from delivered weight and that can be low, also.
My trailer had a brochure weight of 3600#. Delivered weight of 3820#. Scale weight of 4200# on the way home, dead empty. Though this doesn’t change the gross weight, it does change the cargo capacity and makes it more likely you will be nearer the max weight. That will increase the tongue weight, taking away from your truck’s payload.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
wanderingaimles
Is 5568 close enough?
Keystone Premier
