Anderson WDH hitch installation
Snomas
I just installed a Anderson WDH hitch on my new Flagstaff micro mint trailer. The trailer is about 3 Inchs higher in the rear and not level. The trailer porpose's when towing w/ my F 150 but there is no sway. Has anyone installed this WDH and how is it working?
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
6 REPLIES 6
Timtation
If needed you can turn the hitch so the ell is up.
Snomas
I raised the ball as high as I could. it's now 1" above the coupler. I will test it next week.
nutdriver
OP asked about experience with the Anderson. I have the Anderson hitch and really like it a lot. Easy to to hook up and to disconnect. Absolutely, no sway despite some significant winds in Kansas.
As others have suggested, you just need to change your hole position to raise the ball.
Also, the Anderson tech support is very good if you still have questions.
ppine
Raise the truck ball on your ball mount.
GrandpaKip
Sounds like you need to change bolt holes to raise the ball. If you got your truck back to Fordโ€™s specs with the chain tension, the only other adjustment is how high the ball sits.
When I changed trucks, I had to move the ball to get the trailer to sit correctly. I like mine a tad nose down. Measuring on the frame, there was about an inch difference. When I set up, I went to a parking lot that was about as level as parking lots get.
The only porpoising I get is on some stretches of concrete highways. Usually a speed adjustment takes care of it.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
