โNov-09-2014 04:27 AM
โNov-10-2014 10:00 AM
majorgator wrote:
I stumbled across this line of generators this morning and it looks like they pretty much meet every requirement of the RV world. In some cases, it appears they even exceed the benefits of the other major manufacturers. I'm not endorsing them, but just felt I'd pass it along.
Boliy Generators
โNov-10-2014 09:01 AM
โNov-10-2014 06:56 AM
Huntindog wrote:
Major, I noticed that you are pretty new here.
I want to give you a belated welcome to the forum.
Generators are one of the most discussed items here.
So unless it is a brand new product coming on the market, it has been discussed here, and almost always with some first hand testimony.
Great generators are thought by most to be the Honda and Yamaha invertor types. The Champion is making a pretty good case for making it a threesome.
Good ones are what I call the tweeners. Not nearly as loud as the contractor ones from the big box stores, or as quiet as the great ones.
They come with some nice touches for RV use and are really affordable in initial price. The Champion 3500 pull start and remote electric start are the most well known of these.
Then there is the rest, rounding out the bottom. Some may be a little better than the others, but as a class, they aren't considered a good fit for RV use by most.
The Boiley falls into this catagorey.
โNov-09-2014 06:07 PM
โNov-09-2014 04:05 PM
โNov-09-2014 08:55 AM
โNov-09-2014 08:49 AM
โNov-09-2014 06:31 AM
โNov-09-2014 06:23 AM
โNov-09-2014 05:16 AM
BOLIY Pro3600SI (model number matches engine kw output not ac output) is a true Digital Signal Processing
(DSP) inverter generator. Similar models including Honda, Yamaha, Robin Subaru, & Kipor use transistor
induced technology which is just simulated signal processing. With the advanced German made
microprocessor, the DSP processor results in a power conversion rate of up to 22% higher than comparable
inverter generators from Honda, Yamaha, Kipor & Robin. The voltage is adjusted to maintain at stable 120V by
the computer inverter module. The light weight design makes them ideal for transportation without the need
for cumbersome wheel kits and extending handles
