Nov-06-2014 05:35 PM
Nov-06-2014 05:57 PM
turkey stalker wrote:DutchmenSport wrote:
I did forget to add we are not keeping it at home. Would this work fine? http://www.amazon.com/Deltran-Battery-Tender-021-0128-Charger/dp/B00068XCQU/ref=cm_cr_pr_product_top...
Nov-06-2014 05:46 PM
You didn't say what kind of camper you have or if you are able to store it at home or not. If you are able to store at home, just keep the camper plugged in with a heavier construnction style extension cord, plugged into your house outlet (15 or 20 amp breaker). This is MORE than enough to keep the battery charged, as your on-board converter will charge it automatically. Campers are made to be plugged in while camping for weeks at a time, so if you check the water level a couple times to make sure it's not boiling out, there's no reason to remove the battery at all.
Now, if you're storing off site, then yes, bring the battery home and a trickle charger will work just fine.
Nov-06-2014 05:45 PM
Nov-06-2014 05:42 PM
Quality Johnson wrote:
I'm no pro, but this has worked well for me. I just run an extension to the TT over the winter and let the onboard charger keep the battery up. I need my regular battery charger for the car, and figure why buy another one when there is already one on board.
YMMV.
Nov-06-2014 05:41 PM
Nov-06-2014 05:38 PM
