Best sealant for slight roof leak?
jaycoman89
Have gotten a lot of rain lately and noticed a slight drip coming from the roof thats roughly right below the a/c unit... hoping to get down there Saturday to try and mitigate. Any advice on sealants/how best to attack this problem?
18 REPLIES 18
jaycoman89
GrandpaKip wrote:
First, check the a/c gasket by taking off the inside ceiling cover.
Self leveling caulk made for RV roofs should be used for roof maintenance.
Thanks!
BarneyS
Probably just need to go inside, remove the AC ceiling cover, look up into the AC and find the 4 long bolts in the corners, and tighten them up a bit. It is quite common for the gasket that seals the AC opening to compress over time and start to leak. The cure, other than replacing the gasket which means removing the AC from the roof opening, is to tighten the bolts a bit.
Barney
Not towing now.
GrandpaKip
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Lwiddis
I use Heng’s roof coating and Eternabond tape depending on the situation
