Hi All,
Have any of you had a Reico Titan powered jack bind up?
The powerhead is working fine since I switched powerheads to check.
I can use a wrench to get it started and then the power head will move it fine but the clutch will click every now and then. I think it will fail completely soon. I've regularly sprayed silicon lube on the legs as the owners manual suggested.
Any rehab possible on this or is it "order a new one" type situation.
Thanks,
Eric
2002 Ford F-350 CC LB PSD 2007 Travel Lite 960rx Ultra 2018 Keystone Cougar 29BHS
