Black Tank Vent
ianmac23
How do I know if the vent is blocked and how should I clear it. The tank smelled bad during our travels from Ohio to OBX.
Thanks
2010 GMC Sierra, 1500, SLT, Crew Cab, Short Bed, 6.2L, Max Towing Package,2011 Keystone Passport Ultralight Limited Edition
1 REPLY 1
downtheroad
Could be blocked...climb up on the roof and check it at the top for obvious blockage. You can also stick a garden hose in it from the top and force some water down into the tank to clear it.
It may even have been pushed or fallen too low into the tank. If the lower end of the pipe is below the level of whatever is in the tank then it won't vent. The pipe will need to be repositioned. higher.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
