Aug-09-2015 06:30 PM
Aug-22-2015 05:53 PM
bwc wrote:HJGyswyt wrote:
Not to burst your bubble with this cool retro project, but you need to understand the difference between a 3/4 full floating axle and a half ton semi floating axle. You can prop up the back of any truck with springs or airbags, but you are still asking 1/2 ton bearings to carry a load bigger than they were designed to do. Many people get away with it, but truthfully, 1/2 ton axles were never designed to carry that kind of weight. All the best with your project.
X2. I would never have a slide in camper if all I had for a truck was a 1/2 ton. If axle breaks your rear wheel/tire assembly comes off and passes you on the hwy. Too much weight for that truck my friend. LT tires etc will not change the safety factor. A lot of folks talk about tires, springs but first things first, full floater or nothing for me, IMHO.
CB
Channel 17Redneck Express
Aug-22-2015 05:24 AM
Aug-21-2015 09:50 AM
Aug-17-2015 11:38 AM
Aug-17-2015 05:03 AM
niftypkg wrote:
The propane tank storage area should be sealed so there will not be any leakage in to cabin or when fueling.
Aug-16-2015 03:41 PM
Aug-16-2015 03:39 PM
Aug-16-2015 03:34 PM
Aug-16-2015 03:12 PM
Aug-16-2015 03:05 PM
Aug-16-2015 02:39 PM
Aug-16-2015 01:57 PM
a.graham52 wrote:
speaking of propane. is it imprtant to have the heater so close to the tank?.
Aug-16-2015 11:54 AM
Aug-16-2015 11:29 AM
