โOct-14-2016 10:15 AM
โMar-30-2017 03:39 PM
โOct-21-2016 11:29 AM
wanderingbob wrote:
Note To Junket , What are you doing taking an outside shower in 18 degrees , did ya keep your long johns on ?
โOct-20-2016 08:15 PM
โOct-19-2016 11:16 AM
โOct-19-2016 03:16 AM
โOct-19-2016 02:59 AM
Bumpyroad wrote:We ar talking about the furnace, but that is close enough...Huntindog wrote:CaptainYARRR wrote:Nope. Not for me.Huntindog wrote:
You can even run the furnace while under tow. I have done so when temps were in single digits.
I'm guessing that becomes an issue pulling in to gas stations?
Frozen water lines without the heater, or figure out how to deal with it. Your choice.
I don't think that shutting off the water heater for 10 minutes or so to refuel would cause the pipes to freeze. I always shut mine down even when way above freezing.
bumpy
โOct-18-2016 04:06 PM
โOct-18-2016 04:03 PM
โOct-18-2016 03:04 PM
โOct-18-2016 05:01 AM
Bumpyroad wrote:
what is the setup on your rV? does any interior heat get to the tanks? I certainly would not want to chance keeping an unheated tank at 20 degrees for several days.
bumpy
โOct-17-2016 11:36 AM
โOct-17-2016 10:12 AM
proxim2020 wrote:
You would be fine. I've run for days through 20 degree temperatures with a half full tank, about 25 gallons, without freezing issues. It takes quite a while to freeze a full stationary tank and even longer for one that's constantly moving. If you have any unprotected connections or hoses then I would get some insulation on them.
โOct-17-2016 08:56 AM
โOct-17-2016 07:38 AM
