Please explain what you mean by "Construction Specs". What specific info do you need? Capacities? weight? Materials used to construct?
Maybe this?Did a google search for
specifications:
Description
MSRP $14838
Designed with your Family in Mind. Expedition LT gives your family a lightweight, simplified RV that's packed full of features. It's perfect for today's light-duty SUVs and mini vans, and offers a full array of features, including conventional construction with an aluminum exterior, radial tires with easy-lube axles, huge pass-through storage compartment, black diamond plate rock guard and awning.The Coleman 15BH is a mini travel trailer that offers a lot. It has a bunk-house in the back next to the bathroom, a middle kitchen and front u-shaped dinette. The bathroom has a skylight and vent for fresh air, and at just under 19 feet it's an easy travel trailer to tow. Check your local Coleman dealer to find out more about the Coleman mini lineup.
Specs
Weights
Dry Weight3006Gross Vehicle Wt Rating (GVWR)3800
Measurements
Length Feet19
Body
Sleeping Capacity4Awnings1
Operational
Fresh Water Capacity27 Self Containedyes Gray Water Capacity28 Black Water Capacity28 No. of Air Conditionerses 1
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
