crack repair in roof caulking
denbob
I recently bought a 2004 Terry Quantum in great condition. When removing the winter cover, I noticed that a crack had developed along the front roof seam in the old sealent, which I assume is Diclor. It is about 18-24" long. What is the best way to fix/fill in this crack?Also, would Eternabond be ok to use?
3 REPLIES 3
BIKERK9
With a roof that old, I would strongly consider EPDM Liquid Rubber Roof..
It is DIY. It's like covering your roof with a giant white blanket that is UV resistant. Comes with a 10 year warrantee.
DoggyDaddy
2008 Damon Outlaw 37', WH-24, 8.1 GMC
Class A Toy Hauler
DoggyDaddy CommunityProfile
beemerphile1
Eternabond tape, fix it once and be done with it.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
joeyg
Eternabond would be fine, otherwise Dicor Self leveling sealant over the crack works well too. no need to remove the old Dicor, just remove the loose bits, clean it up, and seal over it.
