de winterize
nettech207
S o i went and started to dewinterize my trailer today and when i was running the water pump water was comming out the city water inlet
help?
3 REPLIES 3
Bigbird65
One sure fire easy fix for the leaky check valve problem is to go to a good hardware store and buy a brass ball valve like the one shown.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
brirene
You'll have to take the screen out to get to that. The o ring has become unseated. If it won't reseat, easiest fix is to but a whole new connection.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
ed6713
There is a check valve in that fitting to prevent that from happening.
Turn off the pump.
Open a faucet to relieve any pressure in the system.
Take the eraser end of a pencil. In water fill connection you will see a plunger looking piece. Press it in and out a few times.
Turn on the pump If you're lucky, the leak might stop.
๐Ÿ™‚
