dexter axle brakes for 2695 lbs on 22ft Mallard
msgtord
Has anyone replaced the brakes on a 1995 Fleetwood Mallard with the 5500 gvw and 2695 lb axles? I am trying to figure out the replacement brake shoe part numbers.
Thanks.
1995 Fleetwood Mallard 22B.
2014 Ford F250 Crew Cab. 6.2, 4x4.
5 REPLIES 5
Charles2222
Good info Steve.I just didn't have and wanted to help.
stevepk
Just finished a brake job on my Mallard yesterday. Mine 1 1/2 x 10 part # bp04-065. Got them online
2018 F-250
2017 Prime Time Avenger ATI 27RKS
Charles2222
Oh well,wanted to help.Still try an axle dealer anyway. Good luck.I had Dexter on a '92 Fiver and they were bolted on.
msgtord
Charles2222 wrote:
If you have four(4)bolts holding the brake to axle it's aten(10) inch brake.If it has five(5)bolts its a twelve(12)in.Find an axle dealer in your area and cost will a lots cheaper.Very simple to replace.
The problem is these brakes have a welded on back plate. So the brakes have to be rebuilt piece by piece.
Charles2222
