โSep-08-2019 08:39 PM
โAug-23-2021 09:10 AM
capacitor wrote:
As of its first generation, the Touareg was developed together with the Porsche Cayenne and the Audi Q7, sharing platforms and much technology. The vehicles were developed as unibody SUVs with independent suspension. The initial generation (2002โ2010) offered five-, six-, eight-, ten- and twelve-cylinder engine choices.
Interesting, it pulls the trailer just fine?
โAug-22-2021 04:39 PM
โAug-22-2021 01:42 PM
โSep-11-2019 05:27 AM
Bert Ackerman wrote:
You had four frame cracks at the continuous machine welds where the flange was welded to the web of the main frame rail?
โSep-11-2019 02:41 AM
Lynnmor wrote:Bert Ackerman wrote:
What is the criteria that determines that a manufactured beam is flimsy and somehow weaker than a rolled beam of the exact same dimensions? Why, because its welded together from 3 pieces of sheet? Personal opinion or did someone run the structural calculations.
I did my calculating while I was running weld beads over my four frame cracks.
โSep-10-2019 08:30 AM
โSep-10-2019 08:20 AM
โSep-10-2019 08:13 AM
โSep-10-2019 05:51 AM
Lynnmor wrote:2manytoyz wrote:
My last camper was a 25' Rockwood Ultralite. I could have added one to the back of mine. Here's how...
This is the frame of that TT:
I'm not sure who's camper has a frame and/or rear bumper made as thinly as pop cans, but I've never seen one.
Take a look at those welds where the vertical piece meets the top & bottom pieces. If I am not mistaken, it appears to be just the type of flimsy frame that should be avoided. I would rather have a real I-beam, not something pieced together.
โSep-10-2019 04:57 AM
2manytoyz wrote:
The square tube on the back is actually welded to the I-beam frame. I can stand on the middle of it, doesn't flex.
โSep-09-2019 07:56 PM
โSep-09-2019 03:34 PM
2manytoyz wrote:
Of course it's been done successfully. Here's a link to the related Google images on this topic. Click any of them for more details. Whether it can be done to YOUR camper, is another story.
https://www.google.com/search?q=generator+on+back+of+travel+trailer&client=firefox-b-1-e&source=lnms...
I would simply add a piece of angle iron under the square tube, and weld it along the tube, and to the frame rails. This way the weight can be supported, and more importantly, stop the twisting action of having a generator hanging off the back.
You can weigh your camper, then the tongue weight, then have someone stand on the rear bumper to see how it affects the tongue weight. If you're still in the 10% range, good to go. The rear axle is not halfway between the tongue, and the rear bumper. 200 lbs on the back doesn't equal 200 lbs less on the tongue.
Some states allow triple towing. People add hitches to the back of their rigs. Same idea...
YMMV, but it has been done successfully with other rigs.
โSep-09-2019 12:59 PM
โSep-09-2019 12:03 PM
