Whatever type of fix you do.....if you're screwing something into the wall, watch out how deep you go, not much space before you go totally thru to the outside
*Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - "WOW, What a ride!"
I wanted to share my fix for this. I used some eye bolts (not sure what they are actually called) and a few clips for a draw bar pin and made my own retention system. Anyway, here is a pic..
Thanks!
Jeremiah
TV-2022 Silverado 2WD TT - Zinger 270BH WD Hitch- HaulMaster 1,000 lb Round Bar Dual Friction bar sway control
It’s Kind of Fun to do the Impossible ~Walt Disney~
Thinking back to the pup days :h, my first thought was that the rubber gasket on the canvas, and a little hook/loop on top was ALL that held it. Upon, second reflection....there was a latch similar to the pic below on top...I remember NOW, because they wouldn't latch right if the trailer was not level :S Here is where a similar Coleman part can be found.
