May-16-2016 06:38 AM
May-16-2016 02:58 PM
May-16-2016 09:47 AM
May-16-2016 08:29 AM
May-16-2016 07:52 AM
May-16-2016 07:17 AM
May-16-2016 07:05 AM
bianchina3 wrote:
We took the camper out for the second term last weekend. We had a strange occurance with the front jack.
A little backgroud. I installed a new battery tray to hold two group 27 batteries. Wired them together with a cut off switch on the system. Went to use the jack and nothing happened. I checked all of the electrical and the cutoff was off when we got there (the key was removed) and now it is on. But nothing. I figured that I had something screwed up. Manually craked everything up and figured the batteries had just drained in the month or so we hadn't used it. This would be strange but maybe. Camped over the weekend with it plugged in so the batteries charged. On Sunday went to operate the jack and it still didn't work correctly. It acted as if the batteries were low but did have a partial charge? I put a volt meter on everything and they read full. That is wierd. Any ideas why the strange behavior?
Ed
