larute wrote:
I'm looking for some travel trailers under 24 ft with floor plans like the Keystone Springdale 1740RK. Check it our here: https://www.keystonerv.com/product/springdale/comfort-travel-trailers/floorplans/1740RK
I absolutely love that floor plan, but I've read some negative reviews on that particular trailer. Any suggestions?
Is this your first TT? If so, consider a used one.
Most everyone finds that the way they imagined camping is not at all how they ended up camping. The floor plan that seemed so perfect on paper ended up not being a good fit at all. Perhaps you imagined being all by yourself all alone in the forest but instead use campgrounds or the other way around. Buying a used unit will allow you a trial run so to speak, without breaking the bank if you want to make a change. There is nothing worse than being locked into a unit that is a poor fit for you because of the financials.
Huntindog
100% boondocking
2 bathrooms, no waiting
17.5LRH commercial tires
