โJul-26-2014 03:08 PM
โAug-12-2014 10:58 AM
โAug-12-2014 10:51 AM
campinia wrote:
This is interesting to hear. I just sold our Jayco Swift SLX 184BH with the same set up as yours because the refrigerator would get above 40 degrees during days that the outside temperature would get over 80 degrees... Unfortunately, I tried for two years to find a solution to the fridge and A/C problems and had to sell it. I did not buy another Jayco this time, as they offered no help with these problems.
patkvm wrote:
Yeah Jayco did not get involved until 7/1/2014. I have only owned Jaycos so I did go out and buy another Jayco, but I did not buy another SLX. In the end Jayco did try to right the wrong by giving us the option to trade like we did.
โAug-12-2014 10:44 AM
โAug-12-2014 09:22 AM
patkvm wrote:
EnochLight
I have been following your posts regarding your fridge. I have no answers for you but I would like to share my experience with you. I have a 2013 Jayco Swift SLX 185RB that has the same setup as yours. I have been dealing with fridge problems for a year and a half now, temps rising to over 70 degrees during the day and dropping to 20 degrees at night. The dealer has tried to resolve the problem with baffles and fans. Finally Jayco sent a transport to come and pick the unit up, Jayco and Norcold engineers spent a month measuring and building custom baffles adding bigger and more fans behind the fridge, then they replaced the fridge and repeated the process all over again. During this time that Jayco had the trailer there was some questions regarding the A/C unit that was mounted in the side wall of the trailer. Jayco figured out that when the A/C was turned on the air flow was disrupted from behind the fridge causing it to not cool, the A/C unit that is installed in these units is a window A/C so it will pull the condenser cooling air from the living space. So Jayco when back to the drawing board, Jayco looked at mounting a roof top A/C but due to the design of the trailer it could not handle the loads caused by a roof top A/C. Jayco tried to seal around the A/C but no luck. So they changed the baffles and fan design one more time.
When I got the trailer back last week they completely changed everything behind the fridge. Jayco extended the warranty another year and said it was good to go. We took it out last weekend and the fridge failed again. Since I have owned this trailer I have asked everyone that I came across with a trailer like mine they all say they have some sort of fridge cooling problem.
After a year and a half we have come to no other choice but to unload the unit. We are very saddened by having to trade the unit in but now it is the dealer's and Jayco's problem.
Like I said I am sorry I do not have any fixes or solutions for you but I just wanted to tell you what happened to us in hopes that you or your dealer might be able to pull some ideas out of our story.
Good luck.
โAug-12-2014 06:58 AM
patkvm wrote:
I stuck a mirror inside and ...
patkvm wrote:
Here is the drawing. Not to scale but you get the idea.
https://onedrive.live.com/redir?resid=5493A6C9D07A39BB!1725&authkey=!AB_wkWrtHVid_z4&v=3&ithint=phot...
โAug-12-2014 06:22 AM
โAug-12-2014 05:58 AM
โAug-12-2014 04:24 AM
patkvm wrote:
EnochLight
Good luck.
โAug-12-2014 03:49 AM
โAug-10-2014 11:16 AM
โAug-10-2014 11:03 AM
โAug-10-2014 10:37 AM
โAug-10-2014 06:07 AM
Gjac wrote:
Have you made any progress on your refer cooling?
โAug-10-2014 05:50 AM
