Funfinder 242BDS water heater bypass valve
shacar21
Looking to winterized my 2015 Funfinder242BDS and can't find the hot water tank bypass valve. Only access panel I can see at the rear of the trailer is a panel behind the toilet. Took it off but don't see anything there.
Anyone know where to find it?
Shane
3 REPLIES 3
shacar21
I have the slide out outdoor kitchen and pulled the fridge out but no access panel there. I can see the hot water tank through the fridge compartment vent. Hesitant to start cutting holes...
Dennis_Smith
Do you have a out side storage near the hot water. My floor of it comes out and that is where you find it
sch911
The valves are mostly located on the back (interior) side of the water heater. So approximate where that cavity is from the inside of the TT and then figure out how to gain access. Sometimes it will be a removable panel, but there are other ways, like drawer removal, cabinet side panel removal, access from pass thru storage, etc....
OEM Auto Engineer- Embedded Software Team
