Currenly on a trip and running A/C and not furnace.
The furnace started to make a fan noise and the sound like it's trying to fire the gas.
Moved thermostat to off and back and forth to heat with no change the noise is there yet.
I removed the 15 amp fuse marked furnace and the noise stopped. Problem solved right ? No the thermostat must run off that fuse because then the A/C does not work.
Took access panel off of furnace and can't see any easy fix, that's over my pay grade.
I'm thinking to disconnect a wire to the thermostat that controls the furnace? Which one ?
Furnace is Suburban
Thermostat is Coleman Mach
Thanks for any help
Mike and Donna
2016 Chevy 2500HD
2020 Open Range Light 312BH
