โJun-25-2022 06:57 AM
โJun-25-2022 10:47 AM
klutchdust wrote:I had both tanks (30 lb.) off this morning, so they were disconnected. Same problem when I hooked everything back up.CA Traveler wrote:
Tanks shut down with excessive flow, a safety device. Turn off the tank valves and then slowly open, might solve the problem.
Also disconnect the line going into the tanks. I had the same issue and found the line to be faulty, it was holding pressure.
โJun-25-2022 09:50 AM
โJun-25-2022 09:23 AM
CA Traveler wrote:
Broken pipe or opening tank valve to fast can cause the valve to shut down, ie safety issue.
โJun-25-2022 08:35 AM
โJun-25-2022 07:44 AM
CA Traveler wrote:I'll give that a try. Thanks. I was only using one burner on the stove, so I doubt there was excessive flow. But I will check that. It did continue to burn at a low flame, it didn't shut off completely. But it was barely enough of a flame to slow cook an omelette.
โJun-25-2022 07:25 AM
