has anybody tried these products before
diver57
Thinking of getting the these two products and was wondering if anyone has
any comments on them.
One is the wifi ranger for better wifi pick up http://wifiranger.com
And there other is propane tank monitor system .http://mopeka.com/products/
Thanks
9 REPLIES 9
SidecarFlip
Never considered that (IR). I have a HF one, think it was about 20 bucks.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
work2much
You might also consider a IR thermometer gun. They are cheap and will work on your tanks if you are using propane at the time which creates a difference in temp between the liquid and gas portions of the tank. They are also handy to check things like specific engine component temps, tires, brakes, BBQ grill ๐Ÿ™‚
They vary in price but even a cheap 20 dollar unit will be plenty accurate to check your propane tank levels and a bunch of other stuff.
IR Thermometer.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
trail-explorer
I have the tank Monitors. They work well.
tank monitors on another forum
Bob
randy328
I have both of the items mentioned.
I like the WiFi Ranger as it significantly extends the range of my connections and gives a stronger signal to the closer ones. No issues, nice having a secure network for my internal devices (WiFi printer, for example).
The sensor works as described, I mounted the display along with my other sensors. Only downside is the battery does not seem to last as long as I would like, had it just over a year and replaced twice in one sensor and once in the other. Not a big issue, however. Easy to change.
KZ MXT2920, Ford F250 4dr long bed
Bunch of Motorcycles - Track Instruction and Race
German Shepherd "Qorkey"
deltabravo
MN Ben wrote:
https://youtu.be/d3DE_IDOOrs
Informative video, but the second video doesn't describe an "issue" persay, it's an "operational characteristic" in my book.
The inside monitor is calibrated for 20 lb tanks.
You can buy the system with just the sensors, and use the bluetooth to a tablet or smart phone. The app gives you the ability to set your tank size.
towpro
I bought the Dometic after I ran out in my Wolf Creek and I lost contents of refreg.
The Dometic checker works great. But you need to put one hand on top of tank, then press checker against tank with other hand to have it work perfect.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
MN_Ben
I was interested in the LP Tank Monitor so I did a little research which brought me to a couple of informative youtube videos. The first is the original setup/use of the product and the second is a follow up on the product which revealed an issue. Also in the second video is another LP measurements tool by Dometic.
https://youtu.be/4PTJ1KajJrc
Ben
2006 F350 Dually PSD
2008 Keystone Laredo 29RL 5th Wheel
2002 F250 7.3 PSD -SOLD
2004 Lance 1130 -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
Bedlam
Moderator
Moderator
WifiRanger is a good product, but expensive due to the integration software. If you are technical, you can do this for less money. If you are not, it may be money well spent to avoid frustration.
SidecarFlip
I use a Truma propane monitor, works really well. Handheld, about the size of a mini-Maglite.
