Help needed picking out some 245/70R19.5 tires
pirlbeck
I am looking for some 245/70R19.5 load range G for a 4X4 3/4 ton pickup that mostly will see highway miles. Some of the criteria are as follows.
1, Must be hi quality/reliable.......this truck will mostly be used for long distance vacation trips with a truck camper on it and it may end up on an Alaska trip in a couple of years.
2, As it will mostly be long distance, highway miles, I don't want tires that would be objectionably noisy.
3, Very rarely will be off road, but an all terrain type tread would be OK, so long as they are not real noisy.
4, Was advised to use a straight tread steer tire and an all terrain on the rear, but that limits rotation to side to side.
While I don't want to spend money foolishly, price is not a huge concern. I am willing to pay a little extra for something I will be happy with.
Anyone have any experience with this size tires?
Thanks!
2009 Lance 845
2021 Flagstaff 529RLKS 36'6" fifthwheel
2006 Dodge Ram 2500 Cummins
19.5 Rickson wheels with Michelin XZE tires
Air lift bags with 72000 wireless onboard air
Hellwig Big Wig rear sway bar
Rancho RS9000XL rear shocks
Torqlift tie downs
15 REPLIES 15
Bedlam
Moderator
Moderator
I suggest going with LRH 16PR tires. You will be able to carry the same weight at lower pressures and they will be a little more comfortable.
