Host Mammoth camper
Teagan_s_camper
Picking up camper on Wednesday, little worried about weight. Have 2017
Ram limited3500 DWR with stock rear air suspension . Camper coming in at
4807 lb also once in a while will tow boat 9300 lb. enough truck?
55 REPLIES 55
cartmancartman
Teague did they take care of your issues?
zb39
work2much wrote:
Coincidentally Randall from Host just called. We should be picking up on Monday.
Congrats..................
I ordered mine with the 9k AC. I had no issues running it with a single 2k honda genset
Now that I installed my 6 6volt batts and a 4k PSW inverter. It runs with no issues with or without the genset. My inverter is wired to run the entire camper. It is also a smart 3 stage charger.
I leave my fridge on LP all the time, although I did test it and it runs just fine off the inverter.
If we were plugged in for a few days I would change it back to electric, but we don't do that very often.
Enjoy your new TC, they are nice............
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
work2much
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Bedlam
Moderator
Moderator
Around 10/20 we will be traveling from Reno north on US-395 to CA-44 and CA-89. It looks like both of you are south of my travels.
mike_kellie
Great scenery coming home for you! Colors will be beautiful along Dunsmuir and Lake Shasta.
2015 Host Mammoth triple slide w/ TorkLift Fastguns
2015 Ram 5500 SLT cab & chassis with Douglass 9' utility body
work2much
mike/kellie wrote:
work2much wrote:
I want to have camper in hand to double verify dimensions before ordering batteries.
I'm traveling up through your area in a couple weeks. I'm picking up our Ram 5500 with new body and camper in Bakersfield and doing a fall drive up 395 coming out Tioga Pass around Oct. 8-9th.
If you want to see dimensions, we can meet.
Wow, what an awesome set up! Thanks for the offer, very nice of you!
Ours is supposed to be ready in a week or so to pick up at Host. I think we will have it home by then.
mike_kellie
work2much
zb39 wrote:
work2much wrote:
burningman wrote:
Wait, you're planning on running your A/C on a 3000-watt inverter?
Where will the inverter get all that power?
LiFePo4 battery bank with 600 usable Ah. May increase from there if needed. Plenty of room in the basement.
Are those 12v batts. How many will you use?
Bank will most likely be (4) 200 Ah 12 volts with safe DOD to 80% There is also room to install (3) 300 Ah Batteries. Still on the fence. I want to have camper in hand to double verify dimensions before ordering batteries.
Still wondering if Teagan got his A/C resolved. Curious what the model number on his A/C is. The Penguin is available in several BTU configurations with different power requirements for lock rated amps.
I think I am going to go ahead and install a soft start in ours right off the bat. According to Dometic the unit has a LRA requirement of 56Amps. The surge spec on our inverter will cover that but prefer not to go there on such a regular basis as the AC would demand.
zb39
2022 Host Cascade
maling6154
I am also curious about the result. Hope everything is good with Teagan's camper.
work2much
Is there an update on your new Host Teagan?
work2much
SidecarFlip
From the Inverter fairy.......:S
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Teagan_s_camper
Sent off email to dealer and factory, no response probably because of holiday
Weekend. My big thing is wanted everything done by factory, now l am 9 hours
Away from both.
