May-05-2022 08:35 AM
May-05-2022 05:40 PM
bsbeedub wrote:vermilye wrote:
If he destroyed the cladding on the element it may still work, but cause a GFCI receptacle to trip due to electrical leakage to the water. I'd plug the trailer into a GFCI to check before he ends up in a situation where he needs to plug into one.
He has a surge protector ( don’t know the brand or capability) that he uses at the power pedestal. Would that have tripped if there was an issue?
May-05-2022 05:35 PM
May-05-2022 02:39 PM
May-05-2022 12:30 PM
May-05-2022 12:27 PM
May-05-2022 12:25 PM
May-05-2022 12:13 PM
May-05-2022 08:55 AM
bsbeedub wrote:
I was camping with a friend and his second year trailer this past weekend. He could not get hot water using the electric element so he asked me to take a look to see if we could figure it out.
He has a two valve bypass system (mine has a three valve system so I was unfamiliar with his) and we realized it was still in bypass. After opening up the outside panel we saw he still had the plug removed from winterizing so there was no water in the tank. He had the electric heater turned on for two hours and I told him that the element was most likely toast. We decided to give it a try anyway.
We got the bypass valves in the correct position, put the plug in, filled the tank and in 30 minutes he had hot water! We verified that the electric was being used and not propane. He had hot water for the rest of the weekend.
Everything I’ve ever read or heard indicated that this electric element should have been long gone. Has anyone ever seen an element survive two hours of being on with no water in the tank? Could it have been that since the plug was out allowing air into the tank is what saved it? I’m at a loss.
