Using a solid back board works for us mounting things to the thin trailer walls...
We was not able to tie into any of the so called studs and use MOLLY BOLTS in the four corners of the solid 3/4-1 inch thick backboard section...
You cannot drill into the thin walls for standard screws. They will just pull right out when you try to hang almost anything on them.
Using the wall studs or MOLY BOLTS works great. The MOLLY BOLTS Spread out behind the wall and would be very difficult to pull through. The SOLID BACK BOARD idea spreads out the weight and allows you to use standard wood screws for your TV mount.
Then you can paint the backboad to match your wall decor and looks very nice.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
