Just brought the trailer home from its permanent spot in the California Delta. Getting it cleaned up and doing the routine maintenance has been an annual thing before we take it up to the Sierra for a week’s vacation. As soon as I stepped onto the floor I noticed the soft spot. Something I had dreaded after reading the horror stories on this board. It looks like it extends out about 12” and starts at the center of the door and runs, unfortunately, under the kitchen sink and stove to about the middle of the fridge area. I took the advice from Camo’s thread and setup a tub over the roof vent with my leaf blower stuck in a cut out hole and did a leak test. I checked all the windows, lights, door and seams and only found one leak near the bottom of a window, no where near the trouble area. No noticeable leaks near the trouble area.
Two things I did notice and try to fix a couple of years ago was 1) the door window was just flopping around and not sealed. Water had to be running into the door. I assumed it was getting out somewhere and never noticed any puddles inside. I removed the framing and sealed the window to the frame and then sealed the frame to the door both with butyl caulk. 2) When I was washing the trailer one time I noticed water was dripping from under the wheel well. The wheel well was encased in sheet metal I assume to protect the framing and underside from mud, water and rocks. Pushing on it I could feel water trapped under the sheet metal. When I got the trailer home I removed the skirt and notice the sheet metal was bent upward and attached to the outside of the siding and was not sealed at all. Water would naturally run down the side and under the sheet metal. I sealed it as best I could as a precaution and hoped that Fleetwood had done this for a reason and it didn’t really need sealing.
Obviously the repairs are not going to be fun but doable. I’m dreading having to take the fridge out to remove the cabinet. I’m more worried about what caused the damage. The water lines and drain lines all look good. I’m thinking the wheel well thing might be the cause since it is centered where the damage is.
Any Fleetwood trailer owners out there have a similar experience and found what caused the damage? Any tips on removing the cabinets would be helpful also
Thanks in advance.
2016 Chevy 2500HD LTZ Crew Cab, Duramax
2005 Terry 270FQS
2006 North River 20' Seahawk
