Oct-13-2014 08:57 AM
Oct-15-2014 02:29 PM
Oct-15-2014 12:12 PM
joerg68 wrote:
You start at the bottom and work you way up. The top of the lower panel slides into a channel at the bottom of the next upper panel. If you work carefully, you can reuse the wall panels.
Is there no access from the inside to see what is going on?
Again, read some of the Truck Camper University right here https://forums.trailerlife.com/index.cfm/fuseaction/thread/tid/25966285.cfm - scroll down to "Camper Structual: Repairs"
Don't be scared by what you see there, though.
This thread http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/18228847.cfm shows a bit of the wall designs.
Oct-15-2014 07:12 AM
Oct-14-2014 02:19 PM
joerg68 wrote:
If your camper has the old style aluminum siding on a wooden frame, you can remove it from the lower end upwards. The siding consists of about 1' wide strips running the length of the camper, stapled to the frame. Remove trim and sealant, pull staples, remove siding. You can not remove strips in between.
If your camper has an aluminum frame, composite walls, or any other "more modern" design, things will be different.
Search the Truck Camper University for "rot repair" to get an idea what other folks have done.
You may have just overstressed the mount ... or there may be a structural issue behind 😞
Good luck with the repair,
Joerg
Oct-14-2014 01:24 AM
Oct-13-2014 02:09 PM
