Little Caravan Company
RobertRyan
A New Startup in Australia and their range,they are called " The Little Caravan Company" From 9-11ft
The Little Caravan Company brings a new concept to caravanning
Being so light it can be towed by a 4 cylinder car negating the need for a heavy, thirsty vehicle
Easily stored at home. Can be manually pushed into position.
Compact size allows access into tight,- on and off road situations.
Offers all the mod cons of larger vans. (roll out kitchen, air con, stereo, etc).
Can be optioned to any requirement, limited only by your imagination.
Multi-Layouts available.
Suspension options - On Road/Semi Off Road/Full Off Road.
CHASSIS
โ€ข SUPARGAL G & S CHASSIS
โ€ข 3 & 4โ€ CHASSIS
โ€ข 3โ€ SINGLE AXLE ( 1450KG )
โ€ข 4โ€ SINGLE AXLE ( 1600KG )
โ€ข REAR WHEEL CARRIER
โ€ข UNDERSLUNG WHEEL (BACK DOOR )
โ€ข POLISHED ALLOY WHEELS (15โ€)
โ€ข DROP DOWN LEGS
โ€ข OVERIDE BREAKING COUPLING
โ€ข 2 X 4.5KG GAS BOTTLES
โ€ข WATER TANK PROTECTOR
BODY
โ€ข FRONT AND SIDE CHECKER PLATE
โ€ข RANGER SINGLE STEP
โ€ข HUME TRIPLE LOCK SECURITY DOOR
โ€ข RANGER WINDOWS
โ€ข RANGER PICNIC TABLE (LIGHT )
โ€ข GRAB HANDLES (FRONT & REAR )
โ€ข LED AWNING LIGHTS
โ€ข LED FRONT,BACK AND OPPOSITE LIGHTS
โ€ข 12V POWER POINT
โ€ข TV OUTLET
โ€ข LED TRAILER LAMPS
โ€ข LED SIDE MARKERS
โ€ข REFLECTORS
โ€ข COMPOSITE WALLS
โ€ข THETFORD LOCK DOORS
APPLIANCES
โ€ข AIR COMMAND SPARROW R/C AIR CON (OPTIONAL)
โ€ข RADIO/CD/MP3 PLAYER
โ€ข INTERIOR/ EXTERIOR SPEAKERS
โ€ข SLIDE OUT KITCHEN (2 BURNER, SINK) (OPTIONAL)
โ€ข 3 WAY 120LTR DOMETIC FRIDGE
โ€ข WEACO 90LTR COMPRESSOR FRIDGE (OPTIONAL)
INTERIOR
โ€ข UPHOLSTERED CLUB LOUNGE
โ€ข DROP DOWN TABLE TO BED
โ€ข POLYESTER GLOSS PLY WALLS
โ€ข LAMINATED ROLLED BENCHTOPS
โ€ข GERFLOOR COMFYTEX FLOORING
โ€ข RECESSED FIRE EXTINGUISHER
โ€ข DESIGNER LOCK HANDLES
โ€ข BLUME HINGES
โ€ข DRAWER RUNNERS
โ€ข DOMETIC HATCH (NO AIR)
โ€ข ACRYLIC CUPBOARDS
ELECTRICAL
โ€ข LED DOWNLIGHTS
โ€ข 2 X LED READING LIGHTS
โ€ข DOUBLE POWER POINT
โ€ข SMOKE ALARM
โ€ข WINEGUARD ANTENNA
โ€ข BATTERY PACK
โ€ข 7 OR 12 PIN PLUG
โ€ข ANDERSON PLUG
โ€ข PROSTAR 30 CONTROLLER (OPTIONAL)
โ€ข 120W SOLAR PANEL (OPTIONAL)
PLUMBING
โ€ข WATER LEVEL INDICATOR
โ€ข LOCKABLE WATER FILLER
โ€ข 12V WATER PUMP
โ€ข TAP AND WATER FILLER ON A FRAME
โ€ข 90LTR WATER TANK
โ€ข TRUMA HOT WATER SYSTEM (OPTIONAL)
โ€ข EXTERIOR SHOWER (OPTIONAL)
โ€ข GAS BAYONETE
4 REPLIES 4
RobertRyan
RobertRyan
gbopp wrote:
Neat little rig. How much? :C
No Prices given on their site
Alabama_Jim
There website has a lot more photos of exterior and interior. Looks very nice for a couple wanting a small unit. The MSRP was not listed, you must contact them.
gbopp
