Oh wow, where to start...13k is too much weight for a 250, no matter what the owner says. You need a350, preferably with duallies (although srw should handle that). As for the truck, too many miles, imo. Lots of similar trucks around BECAUSE...that had the famous (or infamous) 6.0 liter Powerstroke, which had its share of problems. Those problems have now been identified and can be remedied if necessary, at which point you will have a towing beast, but you need to learn how and what to look for, to avoid or fix the problem areas. There is no shortage of information here and at other sources if you're wiling to learn. If you can work on it yourself, great,.if not, it could run from a couple thousands to 4 or 5 to fix. Then again, you might find one that has not had problems, or has already been "bulletproofed". You need to educate yourself about this engine if you're considering buying one.
P.S. Welcome to the forum!
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
