My spray port is a bit different - how to winterize it?
marcarolle
Hi,
We bought our new to us 2008 Gulf Breeze in the spring, from a dealer 2hrs away from home.
This summer, when I used the spray port for the 1st time, the water was scalding hot. I looked inside, and for some reason, the previous owner (or dealer) connected the spray port outlet to the hot water pipe rather than the cold! Weird! I did not bother with that as we don't use it very much - and eventually, I will do the switch... when I feel like doing it in the small space...
In the meantime, I'm getting ready to winterize.
My (stupid) question is: when I'm ready to winterize - and bypass the water heater tank - do I treat the spray port the same way I will do with the other hot water faucets in the trailer and pump pink RV antifreeze through that port?
Me
DW
Gouda - 11 months Golden Retriever
Eva Golden Retriever (we miss you!)
2019 F150 2.7l V6 Ecoboost
2008 Gulf Breeze 26RKS
2004 Antigua 215SS Hybrid - gone
2002 Jayco Eagle 12SD pop up - gone
1996 10 ft Clipper pop up - gone
1977 10 ft Lionel pop up - gone
12 REPLIES 12
GrandpaKip
beemerphile1 wrote:
When the WH is bypassed you hook a hose on the spray port and pump a little antifreeze thru.
For those confused, a spray port is common on toy haulers for washing off the toys. If you Google "RV spray port" your queries will be answered.
Ah ha. Thanks for the clarification.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
beemerphile1
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
marcarolle
Trailer has no outside shower. The spray port on the outside of trailers receives a quick-connect coiled water hose with a nozzle. Just to rinse off objects, pets, etc with cold water. Sorry, can't post pic or link.
So from your answers, I understand that by bypassing the water heater tank, the antifreeze should make it to the outside port, just like it does when I open all the other hot faucets in the trailer. Am I correct?
Me
DW
marcarolle
For some reason, my clarification can not be posted... I keep receiving an error message 520. I'll try later.
Me
DW
2oldman
Guess OP is not coming back to clarify.
path1
Wonder what type of check valve between hot water and black water???
If I'm understanding of what OP means by "spray port"
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
rbpru
If the port piping is part of the hot water line system flush antifreeze through it like any hot water faucet.
If it is on the other side of the water heater bypass and directly into the tank, you may need to blow it clear with air.
You do not want to get antifreeze in the water heater tank, a little goes a long ways when it comes to tasting it in the hot water system.
Good Luck
mbopp
Once the water heater is bypassed you should still get water at the spray port. I flush RV antifreeze through mine.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
GrandpaKip
downtheroad wrote:
I'm confused and always trying to learn.....what is a, "spray port?"
Ditto.
Kip
Andersen Hitch
NRALIFR
marcarolle wrote:
.........My (stupid) question is: when I'm ready to winterize - and bypass the water heater tank - do I treat the spray port the same way I will do with the other hot water faucets in the trailer and pump pink RV antifreeze through that port?
Yes. For winterizing purposes it doesn’t really matter whether it’s hooked to the hot or the cold water line. If it’s got water in it it needs to be drained or have pink antifreeze pumped through it.
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
newman_fulltime
I am assuming he is tslking about his black tank flush
downtheroad
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
