Last spring in Mexico, I sprung a leak. It turned out to be the gray tank where the drain pipe exited. Although it was small, but the time it became apparent the entire fibreglass insulation under there was saturated. This meant having to remove the underside in an RV park or I would soon have a big mold issue in that heat & humidity. Unfortunateley since I was the wagon master of a caravan, I did not have the luxury of doing much to it down there, other than allowing it to drip on the ground (thank god it was not the black) I decided enough was enough and I decided to rebuilt the underside using plywood with access panels when I got home.
Finished it this week, except for a few no panic items. Working under a trailer when you are over 65 is no picnic. I have created this web page of it
http://www.mexicocaravan.com/undertrailer.php
