New tow vehicle/old hitch.. What to do?
Headed_West
Going tomorrow to hook the trailer up to the new truck and get it ready for camping season. I have a Keystone Passport 2920BH. I recently upgraded the tow vehicle from a 2013 F-150 3.5 eco boost Super Crew to an F-250 Crew cab 6.2L V8 gas. I have an Equalizer WDH. The question is do I need the WDH?
The trailer Dry is Approx 5700lbs, 1,815lbs carrying capacity. The F-250 is more than enough truck to tow it Loaded to the max. The Equalize hitch is also the sway control, which worked great on the F-150. I assume I will have to adjust the hitch to get it nose down. Will I benefit any with the WDH with this TV?
Any advise and comments appreciated.
2016 F-250 Crewcab 6.2L 4x4
2018 Keystone Cougar Half Ton 30RLI
15 REPLIES 15
ggardne2
In my opinion you will benefit from the weight distributing hitch ... you will want the sway control the hitch provides. Depending on how much tongue weight you have the F-250 will squat down and sit non-level, the rear springs on a SRW are softer than you think so you will also probably benefit from the weight distribution of this hitch.
