newbie start from zero, nothing, nada !
homer1959
Hello guys, im looking for your advice to compare with the one received on an another board.
here is the rig: jay flight 248 RBS 27.5 feet long
Maximum weight fully loaded 7000lbs
tongue weight dry 555
pick up considered:
New silverado 1500 with the tow max package , 5.3 ltr, 3.43 axle,
Am i looking for trouble with this set up, its lots of money so a mistake will be expensive, i know that for some peoples you always need a freightliner to tow something, but hey if we stay reasonable.......
thanks for your input
22 REPLIES 22
homer1959
I am taking notes ! Thanks 🙂
Golden_HVAC
Hi,
ALso consider where the fresh water tank will be within the trailer. If it is forward of the axles, like most are, then it will add some weight to the hitch when you are ready to go camping.
The 2500 is usually a better selection for towing, and will have much larger brakes. Also the 3.43:1 rear axle ratio is pretty tall, in other words more for low engine rpm than for towing ability. It will work, but not nearly as powerful feeling as a 3.73 or 4.10:1 rear axle ratio.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
homer1959
Ok fine guys, ill go back to the drawing table and re-start the whole process better now than too late, thanks !
handye9
Your tongue weight should be ideally 13 percent of the trailer's weight. Use gross weight and never brochure or dry weights for your calculations. 13 percent of 7000 pounds is 910 pounds. The hitch will weigh anohther 75 or more pounds. And then add all the folks, dogs, bicycles, kayaks, tools, supplies, etc. in the truck and you can reasonably figure your truck's payload needs. The 5.3 and a 3.43 axle is not exactly a towing champ!!!! Maybe that is why some folks tow with more truck than you think is reasonable. Because it works better.
Ditto !!!
If you buy a trailer first, calculate 13% of it's loaded weight. Then add that 13%, plus weight of your driver and passengers, plus weight of any cargo you plan to put in the truck, plus 75 - 100 lbs for hitch weight. Take that total occupant / cargo / trailer weight and shop for a truck that has a factory towing package and payload (cargo carrying) capacity, sufficient to carry it all.
Don't listen to truck sales people, when they start talking about max tow capacity. Max tow capacity is determined using a 150 lb driver, who has NO cargo, and NO passengers. As you load the truck with people and cargo, tow capacity goes down, as does the available payload.
Check the drivers door post (on truck candidates) for a tire / loading sticker. It will show max cargo capacity. That number is what you will have to work with. for everything and evrybody you put in or on the truck.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
downtheroad
Bumpy has a good point. When I posted above, I thought you already had the truck. I'd go for a 2500 instead. That gives you room to grow. I promise you, you will be getting a bigger, heavier trailer in the future...WE ALL DID.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Bumpyroad
how much more would a 2500 cost?
bumpy
downtheroad
Good combination. I'd do it.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
jmtandem
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
