No water pressure from hot faucet
kegiddin
We have a 2012 flagstaff travel trailer and are do not have water flow from the hot water faucet. The only way to get water flow is to turn the bypss valve to open. We checked the back of the water heater and remove the connector. Doesn't appear to be a check valve (like I was expecting). It appear to just be a WATTS PEX threaded adapter. Wondering what else could cause no water flow.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" at the top?
    Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post your topic in the RV Forum which corresponds to the subject of your topic. Thank-you!
4 REPLIES 4
1492
Moderator
Moderator
Moved from FORUM POSTING HELP AND SUPPORT
kegiddin
Thanks for the replies.
We removed the piece at the top of the hot water line. It looks just like this: http://www.watts.com/pages/view_image.asp?imgId=6863
Doesn't appear to be a check valve.
The cold water line looks similar although we did not remove the piece.
Artum_Snowbird
Most people do not recognize a check valve when they first go looking for one. Take a picture of the water pipe going into the hot water tank at the bottom, and then take a picture of the outlet at the top.
When you compare the two, you will likely notice that in the top there is a very small threaded addition, only about 3/4 of an inch long, at the top.
That is the check valve. Because you have flow on bypass, it's not the faucet. It's a frozen check valve as Old Biscuit says.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Old-Biscuit
No HOT water flow from ANY Faucet/Shower.......then Check Valve in Water Heater HOT OUT is clogged/jammed/failed
No HOT water flow at one faucet....then faucet diverter valve is clogged/failed (internal cartridge)
