Power Awning Issue/Question
RavensFan24
I have a 2015 Keystone Premier with a power awning. As I was closing up the RV, I noticed that when the awning was closed it wasn't flush with the wall. I haven't had the trailer that long and this is my first one with a power awning. I'm wondering if this is normal or if I should take it in to get checked out. I tried to upload a pic, but had issues (will try and upload tommorow). Overall, its mainly closed, but the outer bar tends to tilt away from the wall instead of being parallel to the inner bar. That doesn't seem right to me, but after trying to manually adjust it doesn't seem to budge much. The awning roll itself is about 2" from fully rolled against the wall. I think the roll should be touching the wall and there shouldn't be a gap between the top of the power awning and the inner bar.
Is this something I should have checked out or is all well in the world?
2010 Chevy Tahoe & 2015 Keystone Bullet Premier 30'
13 REPLIES 13
xr4ticrew
jaycocreek wrote:
Mines like that also but you can adjust/slide the roller left or right so it retracts into place flush.
Can you provide some insight to how this is done? I can make mine move when rolling it up, but it just pushes the other side further out of alignment. On mine both front and rear arms are out of alignment in opposite directions (front towards front of trailer, rear towards rear of trailer).
2011 Chevy Silverado 2500HD LTZ
2017 Rockwood Signature Ultra Lite 8289WS
Community Alumni
Not applicable
samhain7 wrote:
My awning has warnings on it not to retract unless the awning is level (not dipped for water run off).
So that means it is up to me to put it back to normal before retracting...at least that is what I get from it! ๐Ÿ™‚
What brand is it?
samhain7
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
Community Alumni
Not applicable
samhain7 wrote:
DOes your awning have the bars to drop the grade on one side to slant it for water flow? If you retract with those even dropped a little bit you will bend the arms...
Is that a possibility. I have only had two trailers, but they both retract flush.
I have heard of someone retracting their awning with the slant arms bent a bit and it messed up their awning...
In the photos that the OP provided, it looks like an LCI Solera power awning which has arms that can be tilted/folded. These awnings are designed to be retracted with the arms either straight or tilted without causing issues.
RavensFan24
I guess that is a possibility. Seems in 2015 if they have that option to adjust the arm, it should be able to still fold away properly. I opened it up partially and looked at how everything lays in there and it all looked square based on the eye test.
Community Alumni
Not applicable
My previous one did that but not this Lippert one on my trailer, there are bolts blocking it as designed.
On my previous one the frame would occasionally torque which meant I had to bang it flush into place. It would then sometimes bind slightly on the way out then release which is hard on the motor/gears.
This one works much smoother.
... Eric
samhain7
jaycocreek
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
RavensFan24
Yeah, mine works fine too. I feel like I would've noticed it before if it came like that, but I'm not paying as close attention to how it closes up since I'm not manually clicking things into place to put it away or bring it out. I have no reason to think it got bent by my use. I haven't been in any heavy winds or rains with it out. It hasn't been hit by anything and has always been fully away when driving. Seemed odd to me that they would design it to not be flush with the other bar when closed.
xr4ticrew
I have a new 2014 Evergreen I-Go with the same awning and the same concern. I was about to take it back to the dealer to have it checked out as it didn't look right to me.
Community Alumni
Not applicable
It's a Lippert Solera awning and it is designed that way, mine is the same. The outer arms can only come up to the long bolts that hold the rails onto the trailer side; they cannot go in any further.
We use our camper 8-9 months a year and use the awning all the time, it works great.
path1
Ours is like that also.
I think it is the wires to the motor, but I'm not sure. Just looks like it when I poke my eyes in there.
I'm subscribing, hopefully somebody will have the answer.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
RavensFan24
Pics:
Left Arm
https://flic.kr/p/svtSzm
https://flic.kr/p/svsDk5
Right Arm
https://flic.kr/p/svsDtw
https://flic.kr/p/sKJbkf
