Question regarding lap sealant
jbres
Have a brand new Keystone Hideout 27DBS.
I been checking over everything and especially paying attention to my roof, and noticed I wanted to do a little more detail work with the lap sealant. I noticed around a few of the vents the lap sealant has "settled" since the caulking was completed at factory. No problem, I hit it today and now its drying.
My important question is where the roof meets the front of the trailer and where the roof meets the rear of the trailer, it looks to me not enough lap sealant was used. It just seems the whole area looks thin on lap sealant, from side to side.
I realize how to touch up the cracks and small gaps but how do I apply the lap sealant over an entire area span like that to make it "thicker"? The span of sealant is say 2" wide and not sure the self leveling lap sealant will cover over all that....
I used the self leveling lap sealant in the few small areas around vents...
19 REPLIES 19
therink
Me too on Eternabond. Btw- you need to use self leveling caulk on roof penetrations and seams. Lap sealant is for vertical surfaces. Glad to see you are keeping an eye on it. The best preventative maintenance one can do with an RV.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Blackcell
X2 on EternaBond. Once you put this stuff on it's there for life.
EternaBond
2009 Carriage Cameo 35SB3, 12.4K dry, 36' Fiver
2012 F350 6.7L 4x4 Lariat Ultimate FX4, Chrome package, Nav, SRW, CC, LB, 11.5K GVWR, 3.55 ELA, 20" wheels, Toyo AT II, Mor/ryde pin box, Husky 26K hitch
United States Navy Combat Veteran
jbres
Putting eternabond over the top of the existing "thin" factory lap sealant?
Doesn't seem it would be a smooth finish with the eternabond
SooperDaddy
Google EternaBond and use it per directions on the seams. You'll pretty much never have to use caulking again.
My posts shouldn't be taken for factual data, and are purely fictional, for entertainment purposes, should not be constituted as related to scientific, technical, engineering, legal, religious, spiritual, or practical advice. After all it's FREE! Amen. :W
mobilefleet
on front and rear seams I strongly recommend eternabond 4" seam tape, followed by another helping of dicor on top of that. You will never have to mess with it again
