Range hood vent clips/latches?
danimal53
Does anyone know what these are called? They twist into place to hold the damper shut when towing, small plastic pieces. We lost one at some point on the way, and lost the other before we could get somewhere to get replacements. Would camping world have them? I've done some searching online but can't find the right part. I'd like to replace them before I got the road again, and end up losing the whole damper flap.
2010 Jeep Liberty Sport 4x4
2016 Coachman Clipper 17BH
9 REPLIES 9
BarneyS
Screen clips at Home Depot.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Andytis
Same happened to me. I used some screen clips I received with my Harvey windows. They are shaped like an "L", with the nub on the back that fits perfectly into the hole. I removed the short leg of the "L", and popped it into the hole. Looks like it belongs there. Call a Harvey window dealer. Tell them you have Harvey windows and need the replacement clips for the screens. They sent us some for free.
danimal53
LOFAT36 wrote:
Why bother ? Ours fell off years ago and we didn't notice any problem Just MHOP
yea, i figure if the flap itself ever breaks off, then I'll get a replacement for the whole thing. im done thinking about it haha. Current fix, a small bungee, the hooks go in the holes where the tabs were, seems fine.
LOFAT36
bobndot
Seal the flap shut, then see if this marine scupper valve would fit , screwed to the flap. It would probably open from the fan speed then return closed when the fan is off.
http://www.newegg.com/Product/Product.aspx?Item=9SIA67K2K32036&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-Goo...
danimal53
Passin Thru wrote:
Catches, Latches, locking mechanism, lever. You either have to make your own, buy them used from a salvager or buy the replacement vent. For $12, I bought the vent and replaced it. Very simple with a battery screwdriver and took all of 10 min.
****, that's annoying. Maybe a better vent will have better latches? Probably not worth a warranty claim. Surprising that these little clips break off so easily.
westend
Ace Hardware (and others) sell an item called a "screen latch". I have most often seen them galvanized so an owner wanting a color match would have to add paint.
'03 F-250 4x4 CC
bobndot
Heng's (J116AWH-C) Bright White Exhaust Vent Cover
at amazon for 4.95 , you can replace the whole cover for $5.
or fabricate some kind of spring loaded metal clip.
http://www.peninsulaspring.com/custom-clips
Passin_Thru
