โJun-19-2014 07:59 AM
โJun-22-2014 11:12 AM
turboo wrote:
I replaced the bathroom vent cover and found unexposed rubber roof material folded under the vent frame.It was bright white. So the exposed surface I'm seeing on the roof, as shown in the photos is the rubber membrane without the factory white top coating, as its eroded away.
โJun-22-2014 06:47 AM
โJun-20-2014 09:44 AM
โJun-20-2014 09:41 AM
โJun-20-2014 09:40 AM
turboo wrote:
What do you mean "roof base material"? The black spots are in the rubber,not holes that show something underneath .( I think, I'll go up there right now and clean off a spot and take a photo of the cleaned area.)
What is the difference between black EPDM and white EPDM membrane?epdmroofs.org/faq
In addition to the oils and the polymers used to make an EPDM membrane, another ingredient is added to the mix to enhance UV resistance. In the case of a black membrane, carbon black is added, which converts UV rays into heat. With white membrane, in lieu of carbon black, titanium dioxide is typically used to reflect UV rays and prevent it from attacking the polymer.
โJun-20-2014 09:23 AM
DWeikert wrote:mellow wrote:
Coming from someone who is ripping apart a roof that fell apart due to neglect, I would reseal the entire roof, if you are seeing black spots then it is telling you it is time to reseal.
"IF" the black spots are indeed the roof base material showing through then I agree that re-coating is a good idea. On the other hand, if it's just dirt...
โJun-20-2014 09:00 AM
โJun-20-2014 08:47 AM
โJun-20-2014 08:44 AM
DWeikert wrote:
Assuming your roof is EPDM like mine...Does EPDM require systematic maintenance or additional coatings or treatment to achieve its life expectancy?
No. No special coating or other surface treatment is required. General maintenance in the form of good housekeeping should periodically be performed to remove debris and leaves, and to investigate the performance of other components.
epdmroofs.org/FAQ
โJun-20-2014 07:51 AM
โJun-20-2014 07:07 AM
โJun-19-2014 09:28 PM
โJun-19-2014 04:22 PM
โJun-19-2014 02:16 PM
mellow wrote:
I thought Dicor's claim to fame was that you could use their cleaner then put down the lap sealant over top the old stuff.
