Refrigerator drained on to floor- help !!!
takncarabizniz
We just returned from a trip and were cleaning the inside and outside of the trailer. All gas and appliances shut down and I had paper towels lining the base of the fridge and freezer compartments for drip. However, when I came out the bathroom, I discoved a stream of water coming from the base of the fridge cabinet area all the way across the trailer floor. I sopped that up and put paper towels at the corner of the base where the water seems to be coming from.
Does anyone know why or how this could happen? I thought the fridge units had an external drain.
It is a Norcold fridge in a 2010 Nash 27E. This is the first time we've ever experienced a problem like this.
Any assistance is greatly appreciated.
“The world is a book and those who do not travel read only one page.”St. Augustine
2010 Nash 27 E
2005 Ford F-250 Superduty Triton V-10
4 REPLIES 4
takncarabizniz
Thank you for the info. We checked underneath and found nothing out of the ordinary. Will check the drain tube.
2010 Nash 27 E
trnfla
I had the same thing happen and discovered that the drain hole in the back side of the refrigerator was clogged. This is inside the frig on the bottom shelf in the back.
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
kaydeejay
downtheroad wrote:
............Also, frig drain hoses are notorious for getting plugged up.
X2. Happened to mine.
Check the drip/catch tray inside at the back of the fridge to see if it is overflowing. If it is you need to clear out the drain tube (mine was full of spider eggs!)
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
downtheroad
Are you sure it is from the fridge drain?
Possibly a water line or sink drain leaked and the water just found it's way out from the area under the frig.
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
