Well, the starting capacitor did the trick with the A/C.
Now I need a couple more things to be ready for camping season. Has anyone replaced the Fresh Water Inlet on their trailer? Mine hasnever been a good fit and leaks water like crazy. the Plastic "grip" molded to the metal threads has always slipped. I need to replace it with a much higher quality fitting than the junk that came with it.
Any recommendations?
Thanks!
"If you remain calm while everything around you is chaos then you probably haven't fully understood the situation."
2006 Ford F-250, Crew Cab, Lariat, 6.0L Powerstroke
2010 North Country 27BHS
Me- Tommy
Wife- Lisa
Daughter- Makenna
Son- Kameran
