Routine brake/shock inspection, how?
rvshrinker
Trailer is 2.5 years old and has ~ 10,000 miles. How do I check brakes and shocks? WIll have a shop do it if too complicated.
17 REPLIES 17
Lynnmor
We have no idea what axle you have, but here is some information.
Brake material is usually 3/16" thick when new, not 3/8". Most trailers have no shocks, again, we have no idea what you have.
deltabravo
Brake inspection requires removing the brake drum,so you might as well repack the bearings while you are in there.
Bearing repack and brake inspection video on my cargo trailer
jdc1
Pull the trailer wheel off. Remove cotter pin. Remove the large nut. Remove the drum. Look at the brake shoes. The brake material should be 3/8" thick. Any oil around the shock? 10k miles is nothing for a shock, unless you are doing the Baja 500 with your trailer.
