Rubber Hose Sections installed in Grey Water Drain Pipe???
darleyhavidson
Quick question: The TT I will be taking possession of shortly has two sections of rubber hose about 10" apart hose clamped to the gray water drain pipe (approximately 2.5" diameter PVC) before it reaches the outside drain valve.
Is this normal? It looks cobbled together and the sales guy was no help. The sections of hose could be installed to add flexibility when bouncing down the highway? Or maybe the TT was towed and hit road debris and cracked the PVC pipe and that was their fix to get back to camping?
Any practical advice is appreciated.
dh
15 REPLIES 15
SoundGuy
You haven't said but if this is a used trailer then anything is possible ... never seen this with a new trailer.
2012 Silverado 1500 Crew Cab
