Aug-20-2013 06:04 AM
Aug-28-2013 05:27 PM
patkvm wrote:In that case Dometic requires a fan be installed, I don't know for certain about Norcold.
... The refer is installed like a slide out kitchen would be with a bottom vent and a top vent on the side of the trailer. ...
Reese Dual Cam Straight Line HP Sway Control
Aug-28-2013 05:24 PM
I am still wayne_tw wrote:Look at the manual for the Norcold N300, it does not use 12 volts.
.... That Refrigerator requires 12 volts to run the circuit board, so there is 12 volts to the refrigerator.
Aug-28-2013 06:13 AM
patkvm wrote:
I would have thought that there be 12 volts behind the unit but in Jayco's infinite wisdom they only put a 2 way refer in the trailer. So instead of pulling out the refer I thought that I would just run the lead about 3 feet to the battery.
Aug-28-2013 05:54 AM
beemerphile1 wrote:
The most common problem is poor installation. If there is too much space behind the refrigerator or if there is a dead air space above the refrigerator. Often cooling issues can be cured by adding baffles to force the air to flow through the coils rather than around them.
Aug-28-2013 05:25 AM
Aug-28-2013 03:07 AM
Aug-21-2013 06:31 PM
Aug-21-2013 06:08 PM
patkvm wrote:We would like to see them.
... I will try to post pictures of the setup.....
Aug-21-2013 05:59 AM
Aug-20-2013 06:37 PM
patkvm wrote:That unit doesn't have 12 volts, it uses Piezo gas ignition for the LP.
... the refer is a Norcold N300 that is 120v and LP. ...
Aug-20-2013 03:09 PM
Aug-20-2013 01:58 PM
elivi8 wrote:
Why don't you use the Camco solar powered fan vent? Then all the wires are local.
http://www.campingworld.com/shopping/item/solar-powered-rv-fridge-vent-system/47888
Ryan
Aug-20-2013 11:52 AM
Aug-20-2013 07:27 AM
